581 - 600 of 609 Posts
I recently installed Ford Performance "RS" wheels (actually made by Ronal). They are 19x8, 5x108, 50et. I put on Michelin Pilot Sport 4S tires (235/40-19). I was concerned about wheel damage with sidewalls as low as 35 which is why I went with the taller 40, but on my next tire change I may try 35s. At the same time I added 10mm DZX spacers from ST Suspensions which use a bolt-through design with 10mm shank lug nuts, which means I get the same number of turns with the spacers as without.
10mm hub-centric (63.4) spacers from DZX with bolt-through shank lug nuts
A few pictures of the end result...
Fairly subtle change, but I think it looks better with the 10mm spacers, making an effective wheel offset of 40.
If you are not familiar with bolt-through spacers, check out this video (which show larger 15mm spacers, but is basically the same thing except for a longer hub ring)...
Method Wheels: MR502, 38 offset, Hubcentric fit, and load rated for 1850lbs because rally wheel. ;)
BF Goodrich Comp 2 A/S 245/45r17
View attachment 361603 View attachment 361605 View attachment 361607
I recently discovered some rubbing which lead to the inside fender lip cutting the tires up a bit on the outer edge of the tread blocks. I solved it by pinching the lip upwards... but the paint chipped a little. I can touch that up later, but now I know why they say have your fenders rolled by a professional. In retrospect I should have gotten 235's. But I love the look and feel of the larger tires. This set up laughs at pot holes so far, compared to my stock setup.
I like the look of the taller side wall. It fills the fender nicely without having to lower it.
I am also impressed with the spacers. I've seen those before, but you are the first person I've seen post you results with them. The idea behind them is both simple and cheaper than replacing a whole set of wheels.
I had no idea the wheels were made by Ronal. Neat.
I didn't mention it before, but the fitment in the front was super tight at certain turn angles. Straight-on and most turn angles were fine, but there were a few spots where it was almost touching the plastic in the front part of the wheel well. To resolve that, I had a guy use a heat gun and a roller to reshape the plastic. I would still call it close, but it is much better than it was and I'm not aware of any rubbing. I'll keep an eye out for wear signs just in case.
2014 Focus ST ST3.
My Evo x's fitted and formed
I've missed not having 5 spokes, so I've pieced together this set over the last 5 months. So far real happy with how they turned out. Much easier to clean compared to my RPF1's and Assetto Gara's :)
  • Brand Wheel with specs - Speedline / BBS 550 - 18x8.5 et42
  • Brand Tire with specs - Firestone Firehawks Indy500 255.35
Nice, the classic look of Speedlines
2015 PB Ford Focus ST3
Finally took some pics! New wheels are Revolve APVD No. 0119. 18x8.5 +38 with 235/40/18 Michelin P4S on stock suspension. No rubbing issues!
379482
379483
379484
Finally took some pics! New wheels are Revolve APVD No. 0119. 18x8.5 +38 with 235/40/18 Michelin P4S on stock suspension. No rubbing issues! View attachment 379482
Awesome wheels. I posted my Method 501's around Christmas. These wheels remind me of mine. I strongly approve!!! I'm surprised they don't rub? Must be the tire size and brand. At first I thought I had no rub, and then I found these tiny cuts in my tread. I had to bend the front inner edge of my fender to stop the rubbing. If this happens, be careful the paint chips very easy when bending that edge.
2015 ST1
Tried something a little different.
-Volvo Xc turbines 19x8
-5x108 with 42.5 offset
-Achilles atr sport two 235/35/19
-corrected tpms
Ran cheaper tire at stock rs size to feel out wheel fitment. Worked out beautifully, no scrub. The additional 12.5 offset stands really nicely.
