1 - 20 of 651 Posts
· The Mod with a Mouth
Own a set of aftermarket wheels or are you running different tires? Post pictures by using the format below.
I did a search and didnt find anything that compiles all of our cars with the various wheel setups available, so i created this one.
To keep things clean and informative please post in this format:
  • Brand Wheel with specs
  • Brand Tire with specs
  • If the wheels are custom in any way please specify what made them custom
  • Image from front
  • Image from side
  • Image from rear
  • Image from 3/4 front
  • Image from 3/4 front with wheels fully clocked the direction the car is turned
  • Image from 3/4 rear
  • Optional: Image from front without bumper and splash guards off
Tips for good images:
  1. Take shots at a low angle and from 30-50ft away.
  2. Take pictures in good lighting(i.e. sun to your back, sun over head, in a very well lit garage with enough light to see dark wheels.
  3. use a DSLR with a telephoto if possible, if not try finding a point and shoot.
  4. If you are using an smartphone try to only shoot during the day time.
  5. Most of all, this is for informational purposes only, so dont get crazy and photoshop.
Reactions: VividRacing
Yes they are sideways, I will fix them if someone knows how.
These are 16" 2002 Ford Windstar Limited wheels with 215/60-16. Yes they are bigger than stock, but hey they came with the wheel and they are good enough for a winter.
· Premium Member
* Ford Focus Titanium 5 Spoke rims: 5X108, 18X8, with 35mm offset * Goodyear GT All season tires, 235-40-18 * Standard factory stance
Sorry, NYFocusST my submission here is not to taunt you! For others here in the forum, it was a gloomy wet day but I wanted to get these posted for others to reference.
Also these rims are supposed to be < 1lb per corner less than stock!
16" steelies with 205 55 gislaved nordfrosts.They have TPMS but the dealer couldn't get them to link up ????
My “winter” setup. I went with all-seasons because I’ll drive the Expedition in the snow. Just needed tires that would handle under 40 degrees.
Wheel:
Enkei Performance M52 HyperBlack
Offset: +38mm
Backspacing: 5.75"
Bolt Pattern: 5-108
Weight: 20.65lbs.
Tire:
Goodyear Eagle F1 Asymmetric All-Season
225/50ZR-17
1 - 20 of 651 Posts
