Hello guys,
Posting a new post specific to O2 sensor simulators. to those of you who have experience with catles dp, Which is better, Screw in type for rear sensor only, orrr digital version that fixes both upstream and down stream to work in harmony together. I am told that the upstream also needs adjustment for the increased air volume. HERE IS WHAT I AM TOLD from Magnum tuning.com " The life span of a sensor is 50k and We encourage customers to get the dual function simulator because aftermarket down pipes will ruin the signal of the upstream and down stream sensors at the same time. The simulator can replace what the sensors do. We recommend the unit that will act on both of them". what do you guys think. It kinda makes sense to treat the upstream sensor as well.
