I was driving down 95 and the car stalled. I restarted the car while moving and it started, and it started making a weird noise and the oil light then came on and look at the oil pressure gauge and was now sitting at zip, zero, nada, nothing. So I coast down the highway.
I called the shop that just built my motor, they said check for oil other than in the engine, check the oil pressure sensor and make sure it's plugged in. There's absolutely no oil outside of the engine, the sensor is plugged in and there is oil in the engine, damn near full, like maybe a hair from full.
It's showing P0607, which I think means the ECU is bad or something is wrong with it. I don't which fuse it is. Could this be needing a new ecu or would this just be a fuel pump?
