Im in the same boat.. Was looking at the mountune pistons 9.0-1 but there fricken expensive.. I want a little lower compression to be safer
This is a easy fix for lower compression just go with a thicker head gasket gasket like .045 vs .035 and this will bring you to close to 9.0:1.Im in the same boat.. Was looking at the mountune pistons 9.0-1 but there fricken expensive.. I want a little lower compression to be safer
Here's the piston info from the service manual. The material for the pistons is not listed however.Piston
Item Specification
Piston diameter (grade 1) 3.4435 —3.4439 in ( 87.465 —87.475 mm)
Piston diameter (grade 2) 3.4438 —3.4444 in ( 87.4725 —87.4875 mm)
Piston diameter (grade 3) 3.4443 —3.4447 in ( 87.485 —87.495 mm)
Piston-to-bore clearance 0.0009 —0.0019 in ( .0225 —.0475 mm)
Piston ring groove width - compression (top) 0.0484 —0.0492 in ( 1.23 —1.25 mm)
Piston ring groove width - compression (bottom) 0.0484 —0.0492 in ( 1.23 —1.25 mm)
Piston ring groove width - oil 0.0799 —0.0807 in ( 2.03 —2.05 mm)
Piston skirt coating thickness 0.0004 —0.0007 in ( .009 —.019 mm)
