So much this. Unless you plan to go 30+psi, theres no reason to lower the compressionId take 11:1 comp with 20 lbs making 400wheel over 8.5:1 with 27lbs making 400wheel anyday.
Higher compression, more responsive. Nobody is every really below 3k rpms unless cruising anyway. And if you are, just down shift.
Higher compression is just as safe with boost, you just need the octane to support it.
Probably not a good idea. We would run 8th gen civics at 8-10 psi with 11:1 all day and make 400whp. Not very much timing though. Add race gas and we could make another 25-30 whp with some timing and a couple more pounds of boost. They were ticking time bombs at that point. Stock block of courseSo if i wanted to run 11.1 compression and 30+ psi on a 7163efr im screwed? Im running 50/50 watermeth..
and the level of maturity you have.It boils down to the tune and fuel you have available
You should probably just stop now. You're wayyyy off base here. Sounds like you've done too much reading in the internet without knowing what you're actually reading.Id rather have a 9.0 or 8.5 forged steel piston soo im good for 900whp.. Idk y aluminum is being used
shhhh your ruining all the fun. This page has a popcorn bucket waiting for it.You should probably just stop now. You're wayyyy off base here. Sounds like you've done too much reading in the internet without knowing what you're actually reading.
You aren't very smart.Id rather have a 9.0 or 8.5 forged steel piston soo im good for 900whp.. Idk y aluminum is being used
there's a give and take on this one isn't nessarly better then the other when u compare the 2. 2618 is initially stronger then 4032 but suffers fatigue from heat cycling much more rapid then 4032 so they have a lot less of a life span then 4032. 4032 will wear much better and over a long period of time will outlast 2618. Personally unless u plan on rebuilding it often like u would a race motor 4032 is a much better option. The inly real advantage in the end is 2618 ability to withstand a bit more detenation but with how advanced the knock control is. Unless your a total bone head it shouldn't be a problem.2618 forged aluminum pistons are very strong and are usually used in boosted applications where extra ductility is needed. 4032 aluminum alloy pistons are more brittle much like hypereutectics and are much more sensitive to detonation and high cylinder pressures. 2618 pistons are usually produced to allow a larger piston to wall clearance for a given bore size since they expand to a greater degree once up to temperature. I am using a set of 2618 JE grand national pistons in my turbo Buick v8 build. I've done quite a bit of research on the subject. Sent from my SM-N900V using Tapatalk
Got picks of this buick?2618 forged aluminum pistons are very strong and are usually used in boosted applications where extra ductility is needed. 4032 aluminum alloy pistons are more brittle much like hypereutectics and are much more sensitive to detonation and high cylinder pressures. 2618 pistons are usually produced to allow a larger piston to wall clearance for a given bore size since they expand to a greater degree once up to temperature.
Slstomper, these pistons have been "added to the catalog" for a little while now, yes that is correct. As for actually being available to where you can physically have a set, that's now just a reality. SPEEDPERF6RMANC3 have worked step by step with Mahle to design & create the piston line up for the Ford ST. We hoped to help provide a line up the suits everyone's build needs from mild to wildMahle's had these out for a while now. 9.3, 10 and 11:1. I talked to them a couple days ago.
http://www.us.mahle.com/media/motorsports/2015-app-guide-final-compressed.pdf
