Just installed a depo 3.5 as well as a tune today. Stock otherwise. California 91 octane and it's 102 degrees outside.
datazap.me | joshst85 | Focus ST
4th gear pull, eh?Just installed a depo 3.5 as well as a tune today. Stock otherwise. California 91 octane and it's 102 degrees outside.
4th gear pull, eh?
I don't see any knock counts in the log? Cylinder 1 is consistently pulling timing -- more so than the other cylinders -- and your OAR is only -0.21, so would be nice to know how many knock counts you saw especially on cylinder 1 during that pull.
The FMIC is clearly doing a good job, and I know Cali gas is not so great, but as/when (if?) your OAR gets more negative, the tune will be trying to add more timing. It would be nice to know if the timing is just being pulled "because tune" or "because knocking". If the latter, you'll need better gas.
Hope that helps,
Mark
It's hard to say how many knock counts are "bad", and generally speaking if you are not seeing big negative corrections (like, -1.5 or greater) you should be OK. But, tuning you must remember is "pay to play" so engine damage is always a risk...Ok so I switched to mountune and grabbed this log. Should I be worried about the knock count even thought there are barely any negative corrections? All tuners have never said to monitor knock count..they seemed more concerned with corrections, but now that I monitored the knock count and see it get to 5 it has me a little worried
datazap.me | joshst85 | Log 1471211527
when it comes to engine specifics for tuning, im pretty new.4th gear pull, eh?
Hope that helps,
Mark
What's up with that Afr? Full boost and wot and Afr is at 13.08. that's super lean is it not?
Sent from my SM-N910P using Tapatalk
This log. If you scroll down to the 3 second period you see full boost, 100% throttle and 13 Afr.Ok so I switched to mountune and grabbed this log. Should I be worried about the knock count even thought there are barely any negative corrections? All tuners have never said to monitor knock count..they seemed more concerned with corrections, but now that I monitored the knock count and see it get to 5 it has me a little worried
I'm no expert at all. I just thought Afr should be around 11 when wotHmm...I'll switch to the low boost slot until I hear back from the tuner then. I'm not really familiar with datalog readings so I don't know by looking at it myself what is good or bad.
This is the tune I was using before when I was completely stock and I haven't got it revised since putting on an intercooler. I figured an intercooler would just make everything safer anyways so I wouldn't have a problem running it without a revision yet.
I'd read the Stratified Tech articles and the Cobb documentation; both presume you know a good deal about how modern engines work, the difference between a MAP and a MAF sensor, etc. so if you don't, there's a lot of Googling in your future!when it comes to engine specifics for tuning, im pretty new.
Do you know of a good place to go to to read about all of these things, kind of like an overview? Ive done some digging and learned a little about knock, but I would like to understand all of the timing angles better as well as the other aspects. I have yet to come across a good read that ties alot of the different aspects all together.
any info is appreciated
good thing i know that stuff!I'd read the Stratified Tech articles and the Cobb documentation; both presume you know a good deal about how modern engines work, the difference between a MAP and a MAF sensor, etc. so if you don't, there's a lot of Googling in your future!
https://www.stratifiedauto.com/ Click on the Tech Articles menu link
For Cobb, look at the AccessTuner Support page:
https://cobbtuning.atlassian.net/wiki/display/PRS/FORD+ACCESSTUNER+SUPPORT
Hope that helps,
Mark
