1 - 12 of 12 Posts
Hey everyone. So for some reason whenever I'm at a stop light, and I start to go I'll get up to -5.50 corrections on cylinder 3. Only happens in 1st gear. It'll add timing and then all of a sudden when I get to 3k rpm it'll start to pull timing. I just monitored knock count on cylinder 3 and it got up to 15 in the span of 1 second! I have K&N filter, flowmaster cat back, levels intercooler, cobb RMM and tuned. When WOT there's not a single negative correction to be seen. It was doing it back when I had the stock RMM and stopped doing it when I got the Cobb. Now that it's settled it seems to be coming back. Maybe time to go to CPE stage 2? Thoughts?
Mine is doing this somewhat regularly too. Nothing but positive corrections up to +4 under any other driving conditions. But occasionally after leaving a light it will do this(cyl 2 or 3) Oddly enough it has never done it when leaving my driveway or stop sign on my road. I just had the driver and passenger side CPE motor mounts installed hopefully I'm just picking up some extra vibrations from them causing it. I asked Alex about it in my last email I sent him, waiting to hear back.
Check your spark plug gaps and make sure they're tight. I've seen people report on getting massive corrections and knock from a loose spark plug.
I've checked all gaps at .027. Plugs are only 4.5k kms old and I checked them at 3k. Even replaced my problem cylinder coil pack thinking it would cause it (I broke it actually but maybe thought it would fix).
I am sure you realize this but seemingly being isolated to cylinder three automatically eliminates a bunch of possible candidates:
fuel quality, air quality, air temperature, etc. Leads me to suspect something mechanical like spark plug, or injectors?
But I keep my mechanical knowledge fairly limited so thats about as much advice I can muster up. Whether its good advice or not is even questionable.
Based on the fact you said that the RMM fixed it for awhile id say you are getting a false knock reading.
Reactions: brian60
Yeah it's only cylinder 3. My OAR is perfect at -1 and my AFR is at 14.70. I've replaced the coil pack as I've said and I checked the spark plug and it's fine. My next thing I'm going to do is see if anything is hitting the block. It's funny, when I start in 2nd, it doesn't do it. It's only in 1st.
I'm with Tyler if it's ONLY happening in that one cylinder.
Discussion Starter · #11 ·
Yeah it is. 1st and 4th are fine. Not a single negative reading what so ever. 2nd will get the occasional -0.25 to -1.00.
Ever find a solution for this?
I'm getting negative corrections in the -4s in cylinder 3 only. Others are normal. Happens in first gear and seems to happen most often accelerating into a left hand corner from stopped.
I have NGK one step colder plugs that I installed a couple weeks back gapped to .026. I guess tomorrow I can pull the plug and inspect it and reinstall. Any thoughts?
By the way is cylinder 3 the second one in from the drivers side?
1 - 12 of 12 Posts
