1 - 5 of 5 Posts
Trying to fit this engine to my elise and just need to know what the below is used for on the ST focus, one end goes to the inlet the other is cut.
Also on the outlet of the water, i have the return for the oil filter cooler (heater) and the main outlet but what is this one for, i assume its the heater can someone confirm this please
The first picture if the fuel vapor line. The cut off portion routes back towards the firewall and has a TI-Locc quick connector to another line, which then leads all the way back to the vapor canister rearward of the fuel tank. The plastic housing with the sensor needs to be attached to a metal bracket that is bolted to the bottom of the fuel pump.
The open outlet in the second picture connects to the coolant reservoir circuit. A tube goes out from that outlet to a T-connector, which then sends one tube to the bottom of the degas bottle, and one tube to the oil cooler. The other tube attached to the oil cooler then leads to the heater core.
Excellent many thanks
Can I leave the fuel vapour line open or does it need a back pressure
1 - 5 of 5 Posts
