I have a Cobb catted downpipe, 200 cell, that I'd like to install in the near future. Turbo will be stock, likely a Stratified tune, & the Vortech FMIC (autox rules for STH class). What sort of defouler should I use or is it even necessary?
Doesn't matter, but mine is pointed forward.Might be a rookie question, but what direction should the J face? Toward the rear or the front?
Here is the video I followed, step by step:Might be a rookie question, but what direction should the J face? Toward the rear or the front?
I'm using the middle size on a cat-less down pipe; no codes.Defouler end should point upstream. Gonna do mine shortly. Anyone know which size insert would work best for a Mountune 200 cell catted DP? I'm guessing the middle one.
Would the O2 sensor not respond or throw a code if it the flow weren't enough? My thought here being that a mid-sized restrictor could be too much restriction when used in a 200 cell cat--this is assuming my first question is true.I'm using the middle size on a cat-less down pipe; no codes.
I believe just the opposite; it would give a code if there was too much flow and the o2 sensor got a good whiff of what is really going on.Would the O2 sensor not respond or throw a code if it the flow weren't enough? My thought here being that a mid-sized restrictor could be too much restriction when used in a 200 cell cat--this is assuming my first question is true.
When you're done can you post up what insert you used with the Mountune DP and whether it threw a code or not. I will be installing mine at some point and was going to use the middle one but will wait and see how yours turns out.Defouler end should point upstream. Gonna do mine shortly. Anyone know which size insert would work best for a Mountune 200 cell catted DP? I'm guessing the middle one.
Absolutely. Check my most recent OP as I'll be updating that one for sure in the future. I'll try to remember to reply here, though.When you're done can you post up what insert you used with the Mountune DP and whether it threw a code or not. I will be installing mine at some point and was going to use the middle one but will wait and see how yours turns out.![]()
Yes, but only after I went to Cobb Stage 1. 99% sure the car was on stock software and it never threw a CEL prior. Code is P0420. Odd.Are you having a code with that Mountune 200 downpipe?
Yes. You can set "02 slow response" codes by running too small of an insert. I have a J defouler with no insert on my catted downpipe and it's been fine for 30k miles, stock tune and two EPA compliant big turbo tubes.Would the O2 sensor not respond or throw a code if it the flow weren't enough? My thought here being that a mid-sized restrictor could be too much restriction when used in a 200 cell cat--this is assuming my first question is true.
Gonna install it by this Sunday as I was cut for time this weekend. I'll try the middle of the three restrictors. I'll make sure to use anti-seize; got a preferred brand?I would try the middle one before the smallest/most restrictive one since the smallest is probably more for a catless dp and definitely use some anti-seize. I believe some even get a spare O2 sensor just in case it breaks.
Okay, so in that case would it make the most sense to start with the freest-flowing restrictor and then work up? If the rest of my emissions checks are good-to-go would I immediately see a change in the status once I swap in the right size or would I have to wait for another drive cycle? This is assuming I don't reset the ECU.Yes. You can set "02 slow response" codes by running too small of an insert. I have a J defouler with no insert on my catted downpipe and it's been fine for 30k miles, stock tune and two EPA compliant big turbo tubes.
Ordered some Permatex, which is good for O2 sensors.Gonna install it by this Sunday as I was cut for time this weekend. I'll try the middle of the three restrictors. I'll make sure to use anti-seize; got a preferred brand?
