181 - 200 of 224 Posts
Discussion Starter #181
I noticed this as well. You jumped from 245 to 280 and it appears all that was done is a charge pipe upgrade. Was that the same dyno different day or two completely different dyno's and a pro tune? Can you comment on your AFR before and after the pro tune at that stage?
Correct, just the charge pipes... the pro-tune found that power...
I'm sorry, I can't explain the variations of the AFR before and after... guessing the tuner was able "fine" tune this... I leave that stuff up to the professionals. :)
What kind of timing difference on the top end do you see from before meth and after?
Discussion Starter #183
Man, sorry don't know that information...
Discussion Starter #185 (Edited)
Ah it's ok. No datalogs?
He didn't log using the AP.. so I left it at that.. I'm trying to get some done myself, but I don't really want to get on it lol.. we are still addressing the TTR manifold heat soak issue, even though I have the "check valves" the mani is SO hot that we think the meth isnt able to stay "primed" in the lines..
Reactions: screwdgie
DAMN! I need to stop watching your build! I keep wanting to do more and more everytime I read it! Nice build!!!
Now that you've got all this power, it's time to throw some slicks on the front and take it down to MIR. C'mon Steve you know you want to...
Discussion Starter #189
Well.. finally went to trap this b!tch.. lol.. it was so much harder than I expected..
Reactions: Ocysp
Steve your my hero!!
Where did you order your aqua mist kit from?
Discussion Starter #193
Any pictures on tank you went with and where you mounted it at?
Discussion Starter #196
Discussion Starter #198
Painted my mountune IC..
Reactions: BADWOLF
Discussion Starter #200
Reactions: BADWOLF
