1 - 19 of 19 Posts
My 2015 Focus ST is now beeping 3 days every 30 seconds in my garage, theres a flashing red light info indicator but that indicator is the alarm i think.
The beeping comes from the outside, i did make a short video about and you can hear it beeping 2 times with all doors closed and locked.
Can someone explain what it is?
Take it to your dealer. There's a TSB concerning it and they're supposed to fix it. Go here for the actual documentation: tsb14-0124.pdf
Do you hear it if when you park other places? Cause that definitely sounds like a smoke detector.
Reactions: Switch0r
It is the sound symposer. Mine did this. When it goes bad it continually turns itself on/off and trips that beep. I don't know what causes it and I just ripped mine out and got a symposer delete plate anyway. But it's nothing to worry about, it won't cause any issues other than annoyance until you get it fixed or remove it. In the mean time you could simply unplug it, but leave all of the hardware in place until you decide what to do with it.
[edit]: it does not throw an engine light or anything of the like if you unplug it, either. In case you were wondering.
Discussion Starter · #15 · (Edited)
Did you remap your car because this sound symposer beeping came after a remap for me.
1 - 19 of 19 Posts
