Thank You! Does the same point still apply with the parts in regards to the only Installed part by dealer or authorized center, being the Upload and plugs. The other items you can do yourself?MP275 maintains warranty if installed by dealer. MR300 does not. If you are shopping on mountuneusa.com look for the green Warranty Safe check mark to tell if a part is warranty safe.
I plan on doing the rich man's(I'd say poor mans but it's not cheap!) MR300 which is the MP275 with updated charge pipes, Cat Back, Updated recirculation Valve and the upgraded Air intake hose. This should keep everything CA Legal as I won't be altering the catalyst nor is there any major change in the Air intake other than smoothing out the flow less restriction.Thank You! Does the same point still apply with the parts in regards to the only Installed part by dealer or authorized center, being the Upload and plugs. The other items you can do yourself?
