1 - 8 of 8 Posts
2016 Ford Focus ST3
Awesome....I had the other kit in my cart for a bit yesterday but the BF sale only knocked $25 off of it....ended up buying just the Mountune BPV knowing that I will probably pull the trigger soon......Once it is installed you need to let us know how you like it.
I've had it for about 15K miles, and to be honest I forgot what a stock car is like, From what I remember when it was installed it gives a smoother delivery of power.
Reactions: Toadster
I highly recommend an investment in water-methanol injection.
A simple Stage 1 system is enough, because you will not get full power out of this investment without it.
91 is simply not enough octane and again Mountune's rating are based on 93 octane fuel which isn't available in California.
You will pick up 10-12 hp without any tweaking. If you experiment with the mixture you might pick up more.
Reactions: Toadster
2016 Ford Focus ST3
not really needing water/meth - this is a daily driver and yes I understand that CA is limited to 91 octane...
1 - 8 of 8 Posts
