1 - 5 of 5 Posts
I thought I post up how I installed the Mountune FMIC brackets, I don’t remember where I found these pictures on the web, but it was the only orientation I found that was correct. I wish I would have took more pictures but hope this helps a little.
Discussion Starter #2 (Edited)
On the 2015+ the horns are on both sides, I mounted the passenger side with supplied bracket above fender well.
The drivers side horn was mounted on a higher up bolt with stock bracket and horn rotated backward and bent up to crash bar. The angle was perfect to just clear the fog light angle in the bumper cover when installed. It would have been better to tuck it in a little further behind crash bar, but it worked.
Discussion Starter #5
No, it is center between crash bar and radiator, I tightened it down to the metal bushings, so there was not that much flex.
1 - 5 of 5 Posts
