Vendor
The Damond Motorsports Full Motor Mount Set for the Focus ST is here! Get your car fully mounted with our specially designed mounts that hold the motor solidly in place.
The Damond Motorsports RMM/PMM/TMM design:
-The bushings are oriented properly to support the motor and absorb vibrations across the whole bushing.
-This allows us to use stiff bushings without increasing NVH to unbearable levels. Orienting the bushing carrier in a transverse manner further reduces NVH, as less stress is put on bushing flanges.
-Full length welded steel PMM/TMM bases, and top PMM/TMM pieces.
-CAD designed, and FEA, and street/track tested. You can't make enough power to break this thing.
-Factory mounting points are retained.
The Damond Motorsports RMM/PMM/TMM specs:
-Machined aluminum bushing carrier, and RMM, anodized gold or black
-PMM/TMM lower mount bases and PMM/TMM top bases are corrosion resistant high strength steel, with super thick gloss black powder coating
-All high grade fasteners, and lock nuts
-OTS Energy poly bushings
Side Mount Combo
