If you are looking to add more power on the 2013-14 Ford Focus ST, you need to free up the airflow going to the engine caused by the restrictive factory air intake system. The Injen SP Short Ram Air Intake replaces your factory intake system with larger diameter, free flowing piping that has minimal bends and a large cone air filter. You will see performance gains of +8.59HP and +22.14TQ at the wheels on the 2013-14 Ford Focus ST after installing this Injen SP Short Ram Air Intake.
When you're not enjoying the new found power and awesome turbo spool/blow off valve sound during spirited driving sessions, you will also see an improvement in gas mileage since your engine doesn't have to work as hard to make more power. The Injen SP Air Intake is one of the easiest to install performance upgrades that only requires basic hand tools and 30 minutes of your time to install. For extra style under the hood of your 2013-14 Ford Focus ST, this Injen Air Intake is available in polished, wrinkle black and wrinkle red finishes.
This Short-Ram Type Intake features a Heat Shield specially designed to keep hot air away from the intake. Engineered with a direct fit install in mind, this intake installs using OEM hardware and does not require cutting any hoses or modifying any harnesses to install. As an added benefit, all PCV/Emission Control Lines connect to the Injen Intake as OEM.
Injen SP Air Intake for 2013-14 Ford Focus ST Features
Manufactured In California, USA
+8.59hp +22.14TQ AT THE WHEELS
Power & Torque Increased Across Entire Rev Range
Free-flowing, larger diameter intake tubing
Increases in performance and engine response
Includes Heat Shield
Improves acceleration
Better gas mileage
Turbo spool becomes more apparent (sound is increased)
Engineered with Injen-patented SP Technology for optimum airflow
Easy to install, only requires basic hand tools
Available in polished, wrinkle black or wrinkle red finish
Injen SP Air Intake for 2013-14 Ford Focus ST (SP9001)
Should you have any questions, please feel free to get in touch with me directly!
