Flow Form Casting is a production procedure that turns the wheel (or rim section) over a special mandrel and three hydraulic rollers using tremendous pressure. The pressure and turning then force the rim area to form against the mandrel, creating the shape and width of the rim. During Flow Forming, the rim actually "flows" down to create the full rim width. During Flow Forming, pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel.
Don't hesitate to PM/Email or call me direct if you have any questions (714)582.3330 extension 8002 - just ask for Jurrian when you call in!
Forgestar wheels are fully customizable between the set parameters of offset and color. Each wheel option has it's own set parameter of offsets, so if you have a particular offset you wanted to run, don't hesitate to ask me if it would be an available option, or you can check the guide below. These Forgestars are high quality Flow Formed wheels with the full durability of a Forged wheel, that is lightweight, and easy on the wallet. All wheels are TPMS compatible and clear OEM Calipers and Aftermarket BBK's with ease. These wheels are made to order, so if you're ready for your Forgestars, put your order in and we'll have Forgestar make them for your car.
Other finishes are available, the full list can be seen on the website on the pull down menu.
Forgestar F14's are a classy mesh design that works on anybody style. You have options that range from 18", 19", 20" and 22" in this particular wheel. Ranges of widths can go from 8.5" wide to 12" wide depending on your fitment. Of course not all this might be applied to your Focus ST, but they are indeed available. Offsets are particular to the diameter of wheel you select. Here are your options depending on fitment size:
Forgestar F14 Wheels for 18"
18x8.5 offsets from +26 to +50
18x9.0 offsets from +20 to +55
18x9.5 offsets from +26 to +60
18x10.0 offsets from +16 to +42
18x11.0 offsets from +23 to +55
18x12.0 offsets from +36 to +68
Forgestar F14 Wheels for 19"
19x8.5 offsets from +26 to +48
19x9.0 offsets from +20 to +55
19x9.5 offsets from +4 to +42
19x10 offsets from +20 to +44
19x11 offsets from +23 to +55
19x12 offsets from +36 to +68
CF10's are a 10-straight spoke wheel that is aggressive, yet classy at the same time. With it's lightweight and superior design, you will see weights at 24lbs for a 20x10" wheel. Not only will this improve your car's handling by the width upgrade, but because of the lack of un-sprung weight, you can significantly increase the overall feel of the car by it's acceleration and braking.
Forgestar 19" CF10 Wheels
19x8.5 offsets from +14 to +52
19x9.0 offsets from +20 to +60
19x9.5 offsets from +2 to +42
19x10 offsets from +8 to +48
19x11 offsets from +21 to +61
19x12 offsets from +34 to +74
CF5's are obviously the most simplistic of the batch, only being a 5 spoke wheel, but it's also one of the strongest available. With a simple clean look, the CF5's will bring you a new look to your Focus ST without being too drastic, more of an OEM Plus look. With fitment ranges between 18", 19" and 20", you have a great selection between an absolute track destroying 18" wheel set, or a classy show stopping 20" set.
Forgestar CF5 18" Wheels
18x8.5 ET10 - ET50
18x9.0 ET15 - ET55
18x9.5 ET22 - ET62
18x10 ET10 - ET50
18x11 ET23 - ET63
18x12 ET36 - ET75
Forgestar CF5 19" Wheels
19x8.5 ET10 - ET50
19x9.0 ET16 - ET44
19x9.5 ET10 - ET50
19x10 ET16 - ET56
19x11 ET26 - ET69
19x12 ET42 - ET82
The newest edition from Forgestar the CF5V is now also the lightest version of the line up. Only available in 19" these CF5V's are very lightweight, clears most big brake kits, and offers a large range of offsets to pick from. Also in the rotary forged construction, these wheels offer lots of custom color options, sizes and offsets.
19x8.5 ET10 - ET54
19x9.0 ET12 - ET60
19x9.5 ET-2 - ET48
19x10 ET4 - ET54
19x11 ET17 - ET67
19x12 ET30 - ET74
