1 - 2 of 2 Posts
Text Font Logo Banner Brand
Get the latest in Ford EcoBoost tuning technology with this NEW Cobb Tuning V3 AccessPORT! If you liked the Cobb V2 then you will be blown away by the features available with this Version 3 Cobb AccessPORT. This AccessPORT V3 gives you the same HUGE power increases the V2 gave you but with the ability to finely tune each AccessPORT to your vehicle; giving you the best tune possible. And with the new easy to use, large LCD screen, tuning and features are easier assessable than ever before.
Up to a 26% Horsepower Increase // Up to a 28% Torque Increase // NEW Easy to use LCD Screen
This Cobb V3 AccessPORT unleashes the hidden power within your Focus ST by taking off the the restrictive factory settings and software. This V3 plugs into your OBD port and flashes your Ford's computer (ECU) in a matter of minutes in order to fully optimize the engines and turbos potential. The tuning is extremely flexible and allows you to choose on the fly one of the performance maps that are already loaded onto the AccessPORT. This tune is an ECU flash, not a piggy-back tuner, there will be no added devices to your vehicle's ECU.
Up to a 26% Horsepower increase!
Up to a 28% Torque increase!
NEW LCD screen for ease of use.
Installs in minutes using easy to use AccessPORT interface
Installs via OBDII connector, no tools required
Grows and changes as your modifications do
Uninstalls in minutes to return your ECU to stock configuration
Integrated performance tools to record 0-60 times, 1/4 ET & trap speed
Intuitive DTC code reading to help diagnose issues
Easily clear ECU codes
30 day satisfaction guarantee
Downloadable free performance maps as released
If you have any questions, or you would like to order, feel free to call me directly at 714.582.3330 extension 8002, or ask for Jurrian :)
Larger, full color, higher resolution screen...
We super sized the screen for ease of use and better monitoring. Full text help menus, multi-gauge layouts, full map descriptions and more. This screen has room to spare - so no need to run back to your laptop.
Customizable multi-gauge display...
Want gauges? No problem. The V3 now supports up to 6 fully customizable gauges with 1/1000 resolution. Monitor all the parameters you want to see and customize each layout for street, strip or track.
1 - 2 of 2 Posts
