Hey guys! Got an interesting new product for you all. For those who road race you know that this is a common problem on this car, but the brake and gas pedal aren't in line with each other, which can make heal toe downshifting a bit difficult (for the old school guys who still heal toe like me). There is a big ergonomic problem that causes an awkward driving position when needing to heal toe since the accelerator pedal is more sunken into the car than the brake pedal which sits more forward (towards the driver). By adding this Active Shift Designs lift spacer, you actually push the gas pedal closer to the driver to be more inline with the brake pedal to make heal toe down shifting easier. Other pedal spacers on the market are usually made from billet, and extend the pedal out just a little bit more, but most of them fall short, or are too expensive. These are 3D printed high-strength resin which provides an even and level mounting surface for your accelerator pedal to mount against.
These features coupler nuts precisely the right length that thread onto the OEM accel pedal mounting studs and new hardware to safely and securely mount your accelerator pedal. Available in Red, Blue and Black to match your ST, and each spacer features an embossed "ST" logo.
Active Shift Designs Accelerator Pedal Lift Spacer for 2013+ Ford Focus ST & Fiesta ST
Should you have any questions, please don't hesitate to PM, Email or give me a call directly at 714.582.3330 extension 8002, or ask for Jurrian!
