1 - 2 of 2 Posts
So I am looking to get the Mishimoto DIY Intercooler and was wondering if anybody happens to know the size of the mounting bracket that I would need to make? I would like to have it all made up at work before I tear the car apart. I searched but couldn't find any answers. Thanks in advance!
I had some aluminum stock, it was about 1" wide and perhaps 4' long from Home Depot. I simply cut a couple of 6"-8" or so sections, and drilled two holes (one on each end) and had a 90deg bend put into it via a vise and BFH. I used a dremel after to round the sharp corners as well.
You don't need to make it ahead of time. In fact, you will screw yourself in the process! You need to mount where the FMIC will go, mark the holes you need to drill on the bumper support. Then you can template and fab up a bracket. Not before, not after. But during!
1 - 2 of 2 Posts
