Whats up guys. I've had my ST for about 3 years now (57k) and about 8 months ago I had a set of misfires while stage 3 strat tuned. Before that every once in a while when I would get on it the car would about **** on itself. I'd get going then all the sudden the RPMs would pretty much freeze and it would kinda sound like it was limiting itself. So I'd let off and drive like a grandma. Well that happened a few months later and I got a few misfire codes. Ended up swapping plugs and going back to stock for the time being.
Well this morning on my drive to San Antonio I ran into the same issue (note this is like 8 months of being stock with no issues). First I got a check engine for misfire for about 2 seconds (which I barely noticed). Then I was passing someone and that same thing happened where about quarter to half boost and the RPMs would just kinda **** on itself and limit. So I let off and drove the rest of the way fine. I would say this is just the effects of LSPI BUT most of the time this has happened in a lower gear higher RPM.
So what could be the issue? Maybe injectors?
(sorry for any typos)
