The flange end of the depo downpipe will have slotted holes so its possible to mate directly to the 2.5" stock size catback to the 3" end of the downpipe. Provided you have a gasket that has the smaller inner diameter for the 2.5" flange and larger outer diameter for the 3" flange.
There are also adapter flanges that will sandwhich a gasket on either side, in this case a 2.5" on one side and 3" on the other.
There are extensions that comes with various downpipes that neck down for a smoother transition from 3" to 2.5". Its probably the best solution for preserving exhaust flow for the stock catback or 2.5" aftermarket catbacks. Its a negligible performance difference in this instance, but if you feel strongly about it, you don't have to buy the mbrp one specifically.
