Extra hold is good; get it good and wet, this will help things side together. Clamp and tighten; let sit for a bit so the hairspray can "set up".I am currently using t-bolt clamps on everything. My cp-e pipe is at a bit of an angle that causes the clamp to eventually slide off one side. If someone made a 'grippy' clamp I think that woulds solve the issue, but maybe I will try the hair spray suggestion.
How heavy do you spray on the hair spray? And I'm guessing the 'extra' hold hairspray may work better too?![]()
