Vendor
If you're looking for the best cat-back exhaust system to do all performance job on your Ford Focus ST or RS 2016-2017, it has to be Stainless Works 304 SS Cat-Back Exhaust System, and it's now available at CARiD. Each system is designed by the best engineers of Stainless Works, using the latest high-tech technologies. Manufactured of 304L Stainless Steel to the highest standard, it insures years of great sound and killer performance. The system gets it's great sound and look from dual chambered section mufflers and mirror polished stainless steel tips.
Main features:
- Available for Ford Focus 2016-2017 ST and RS models
- Aggressive exhaust growl
- 3" diameter system
- 3" AFM Valve Delete Ground
- Mirror-polished tips
- 304 stainless steel construction with maximum resistance to corrosion
- TIG welded for strength
- Mandrel bent (no buckling) for optimal flow
- Includes all hangers and clamps for easy installation.
This Stainless Works Cat-Back not only sounds great but saves weight as it is 41 lbs. lighter than the factory exhaust system. With the addition of Stainless Works exhaust system to your Focus you would be able to change your exhaust note to a thunderous celebration of small-block power, and see real improvement on the dyno. Still have some doubts? Watch this video and leave all of them behind:
PM me today for a quote or leave your inquiries below.
