1 - 7 of 7 Posts
I think I have an oil leak coming from my check valve on my stage to catch can from JBR. I noticed no other catch can kits have a check valve; it even worth keeping the check valve? I am thinking about getting a different kit. It hardly catches anything. I have 60k miles and I doubt I have caught more then a cups worth over the entire 60k miles. Also it doesn't empty very well (I can hear lots of sloshing around if I shake it, but nothing comes out).
Post pictures, I'm curious.
I have the Damond OCC which doesn't have any check valve. How often do you empty?
Sent from my XT1650 using Tapatalk
Auto part Fuel line Cable Technology Hose
Thats after cleaning. Still some residue. There was a big spot on my skid plate, and it had been pushed back, got the whole oil pan covered. I was really concerned my engine was about to explode until I found this. As best as I can tell thats where its coming from.
Looks like the new Damond kits come with a check valve. I think Ill order their stage 3 and add the 2nd OCC..
I lied, mine has the check valve, lol.
Well no leaks so far...
If you get the stage 2 it basically becomes a stage 3. Is you JBR occ mounted by the symposer?
No, it is mounted closer to the driver wheel.. I am going to relocate to the sound symposer and delete it the symposer though
Discussion Starter · #6 · (Edited)
Okay, Im a bit concerned.. I just ran the car with the drain valve on the occ open.. I was trying to get the stuff that was in there out. I did that! I alot of opaque brown crap came out, along with some oil and condensation, but now my car is shooting out gray smoke from the tailpipe! What did I do?!
1 - 7 of 7 Posts
