So I am installing H&R lowering springs on my 2016 ST. I got the top nuts loose, Wheel speed sensor disconnected, brake line removed from the strut and the bolt in the lower control arm out that presses against the strut.
But I am having an issue removing the ABS bracket that the end link connects too. There is just a nut on the front side of but there is nothing on the back side to put a wrench on and the nut just keeps turning. I have tried multiple wrenches, pry bars and screw drivers in an attempt to stop the threads from spinning when I turn the nut.
I know there are people that have installed springs on a 15'-16'. How did you get this nut off so I can take the ABS bracket off the strut?
