1 - 6 of 6 Posts
Just thought I'd get some input from y'all about the installation order of all the stuff I'm planning on doing to my ST.
Here's what I've done so far:
Injen CAI
MBRP 3" cat back exhaust
CP-e RMM
Boomba BOV
Cobb AP3 w/Feektune
Transmission side shifter bushing upgrade.
What I'm planning on doing:
Coilover kit
Willwood 6 piston brakes front/rear
Boomba short shifter kit
Catless DP
Front and rear sway bars
CP-e FMIC
MBRP charge pipes
CF bonnet
CF rear wing (RS style)
That's the main list anyway... I'm sure there's some stuff I'll be doing along the way that isn't on this list, so what order would you install these items in?
Thanks for the input.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Steel braided brake lines, and brakes. Safety first!
I'll beat that into you're head if I have too!:crazy: Then FMIC, the rest is just up to you/my Opinion, can't really go wrong with everything else. :smile:
Edit: engine mounts? all three Preferable
DP and FMIC are first, since you already have the tune. No difference after that.
6 pot brakes, are not necessary on our cars, and just add unsprung weight.
Hps pads, steel brake lines, and maybe the wilwood 4pot kit at most
Sent from my XT1650 using Tapatalk
The WW 6 pot kit weighs less than stock.
Reactions: Nionetics
1 - 6 of 6 Posts
