Only three passes as late season blow ups and break downs are occurring. You would think after a decade that Honda owners would learn to finish first you must first finish.
Anyway got there at about 11:30 am, track opened at 10 am, first passes started at 11 am.
I changed over to the slicks and let the car cool, first pass (2:36 pm) -
The clocks stop worked because there was a short between the trigger for the Christmas Tree and the rest of the timing system. So the 2nd run resulted in nothing...
Next run wasn't until 6:09 pm, the result was my new PB -
So the darn thing finally ran over 100 mph. I shifted at 6500 1-3 and 3-4 at 6,000
Now if I can put it all together, what do I mean? -
Best 60 ft = 1.76
Best 1/8 mile ET = 8.60
Best 1/8 mile MPH = 80.92
Best 1/4 mile ET = 13.43
Best 1/4 mile MPH = 100.25
My PB was also the first time the car went 21+ mph (21.06 mph) between the 1/8th and the 1/4, that is all shifting IE finding the correct shift point for each gear.
If I get 80+ or better in the 1/8th mph and pick up 21+ mph to the end of the 1/4, that would result in 101.98 mph.
In fact I am close enough to 81 mph in the 1/8th that I could easily run 102 + with the right shift points.
That is possible while the weather is still less than ideal.
I lost in the 1st round of brackets running my PB which meant I broke out (13.50 dial) and dude got me at the about 1,200 mark. It was a 13.50 dial vs a 12.60 dial (Benz E55 AMG) MOV was my reaction time vs his (.658 vs .122) .536 but I out ran him from the 60 all the way 330 mark but after that he ran faster obviously but as I said he caught me around 1200 ft as his 1,000 time was 10.776 and mines was 11.194.
If I got a better reaction time I would have won with a slower ET but break out in the process, oh well.
I only had the spare out. I did my previous best with it in, so I don't think it's that much of a variable.
Config is going to stay like this because I think it will run 103-104 mph as it sits which means it will run a 12 and I that's pretty impressive with just a tune in the car.
Best 60 ft = 1.76
