1 - 5 of 5 Posts
2017 ST2, K&N filter, Exhaust, Turbosmart Kompact Dualport BOV, true vacuum port, symposer delete
So ive searched the fourm for an answer, but havent found an exact result on the hp difference. Im thinking about getting the stratified flash tune, but i dont know if it is worth the extra $75 for both the fuel types. I just want to know the difference between the HP numbers, i could care less about the extra money. I just wanna know because 93 is 50cents more expensive per gallon.
You live somewhere where you readily have access to both 91 and 93? Yes, all things else equal, maybe ~10hp difference between the two. I would tune for the fuel you are most likely to see and use. FYI, you can use 93 octane with a 91 tune (would be safer) but you shouldnt use 93 on a 91 tune. Its not as dramatic of a difference as using E30, if paying for a second tune and you have access to e85, i would do that.
I dont think i have seen anyone provide dynos on this car with a 91 vs 93 tune. I am not sure where, under the curve, the gains are or if only at the peak
2018 Focus ST Magnetic Metallic
I got both 91 and 93 maps from Stratified. I'm happy I did. It makes it great for travelling between states who have different octanes.
Slot 1: 91
Slot 2 : 93
Slot 3: 93 with rev limit (for when my friends/family occasionally drive my car)
Slot 4: Low Boost/Winter
Slot 5: Valet Mode (never letting anyone valet my car so kinda useless. But a lot of people use it for when they drop it at a dealership.
"you can use 93 octane with a 91 tune (would be safer) but you shouldnt use 93 on a 91 tune"
is this a typo, or do you just mean i can use 93oct on 91 tune but i shouldnt? im interpreting this as "is you can use 93 on 91, but you shouldnt use 91oct on 93 oct tune." also, i do have e85 access, but it is a good 20-25 minutes away. i do go out there sometimes for other reasons, but not alot. What is the power like between 93/91 and e85?
93 octane with the 91 tune is safe (using a higher octane fuel on a lower octane tune)
Do not use a lower octane fuel on a tune for a higher one, you will increase chance of knock.
1 - 5 of 5 Posts
