if you make the claps tight you should be all good.anyone have issues with oil vapor seepage via the hoses. i notice it after i shut the engine down and walk around the car, i can smell the oil. no leaks and the hoses are securely fastened.
If there arent any visable leaks then why assume its the occ? Could be a fitting or something installed incorrectly when it was put back together. I would check the fitting on the intake manifold and the other one that had to come off during installation.hoses are clamped, there seems to be an issue with the hoses. oil vapor is seeping through. there are no visable leaks.
Depends on how often you empty it. I usually check mine every 2500mi or so and there’s an oz or two in there..How much oil can be expected in the can?
