21 - 27 of 27 Posts
That is some clean cable routing. I always wanted to get a cam, but did not want the cables everywhere. I might just have to pull the trigger now.
not bad write up, my input would be to buy a hardwire kit and select a switched ignition fuse, in uk we use fuse 85/86.
i ran cable for the front- along headliner, down inside A pilar, removed the dash trim popped cable there and into the fuse box.
The A pillar just pulls inward and pops loose allowing you to easily and safely hide wires, there is a short tether that keep it from flying toward you in am airbag deployment, if you unsnap that test her, then there are clips that will hold the wire in place, it is where the OEM wires are ran down.
Thanks @1LoudST! This is exactly what I was looking for. Did you have to disable the airbag to pull the A-pillar trim? Also, the clips on the trim appear to be single use. This is exactly so the trim piece doesnt fly off if the airbag inflates. Do you know where I could get replacement clips?
21 - 27 of 27 Posts
