1 - 20 of 20 Posts
Just bought a JBR short shift arm to replace my shift plate. I soak with penetrating oil and hammer it with a 3lb sledge for an hour but it looks like didn't move at all. Any idea how to get the pin? Should I drill it out in this case?
Automotive tire Automotive design Bumper Motor vehicle Sports equipment
Update:
Just another try this morning with the originally supplied pin (I'm using my own punch pin set before), and finally got the job done!
I also sprayed and soaked with PB blaster whole night and I think that helps a lot.
Thank you guys for all the support and I'll test out how it feels tonight.
Automotive lighting Automotive tire Flash photography Hood Motor vehicle
2013 Ford Focus ST
It took me awhile, small hammer, lots of tapping and patience. It came out. I used the bolt they supplied.
2013 Ford Focus ST
You don’t want to drill it out since it’s reused with new arm I believe. You could probably rig up a wiper arm puller tool to get it out.
It is not reused. They supply a bolt to use to tap it out, and another with a nut to install on the new shift arm.
2016 ST2, Shadow Black, E30, MonsterFMIC, GFB DVX+ BPV, ALEX' ShiftBushings, PCV-OCC, Innovative RMM
I don't remember my pin being that difficult to remove. I think I used a large 2-3 lb hammer turned sideways. And a large pin punch.
It also looks like you have some oil residue with some collected dirt. May want to check if you need to reseal the shift tower.
I used this on mine and had it out in about 5 seconds. My mother in law bought me one of these years ago when I was building a house for her and it's been useful for a lot of projects.
Craftsman 9-11818 Nextec 12-volt Lithium-lon Hammerhead Auto Hammer https://a.co/d/3Omlakr
modify and use a big C Clamp and push it out
Reactions: thadarkjinja
suggestion from @Biznatch on RS forum:
A c-clamp with a rod on 1 side to push the pin out, and a long socket on the other side for the pint to go in. Should slide right out.
Reactions: Lucada and rob99rt
It comes right out you just got to pull the headlight housing so you have more room and use a long Punch or a punch in a socket on the end of an extension if you need to get a better angle you have someone in the car and shift it to rotate the shaft. I struggled with mine for about an hour and then I did it that way and it was like three taps. I think because it was so long I held everything in line and held to punch on the PIN while my brother tapped to the end with a hammer.
Congrats on getting it swapped. Fwiw, I'm running mine at 20% and it feels great. 40% was just WAY too much for my tastes.
1 - 20 of 20 Posts
