1 - 20 of 236 Posts
Ford Focus ST 2013+ Oil Change Walkthrough
Just rolled over 800 miles, and was bored today, so thought I'd change the oil. I took some pics while I was at it so I could make a tutorial! The ST is a little different than the standard Focus, so I thought it warranted making a new walkthrough. If you've never worked on a car, don't worry; changing your own oil is easy, cheaper than taking it to the dealer, you can control what oil goes into your car, and most importantly, you can make sure the mechanic doing the rush job at the dealership doesn't strip the threads in your aluminum engine block, or "forget" to change the filter.
You will need some consumables and tools before starting:
Pictured are a hydraulic floor jack, jack stands, and a drain pan. These were purchased at walmart. Some people like drive-on ramps; I chose the jack and stand because they are 1) cheaper, and 2) allow you to take off the wheel for suspension and brake maintenance. The ramps are certainly faster though. Up to you. I would not use the included scissor jack in the spare tire compartment because it will scratch the paint off the rail. Keep it for emergency use and buy something else for routine maintenance or part installs.
You'll also need 6 quarts of a 5W-30 oil of your choice (extra quart not pictured), an oil filter of your choice (the factory recommended replacement is a Motocraft FL-910S), a funnel, a filter wrench (optional), a torque wrench capable of measuring 20 ft-lb, a T30 torx driver or ratchet, and a 15mm wrench or socket. Also have some paper towels handy.
Drive your car around a little bit to warm up the oil. This lowers the viscosity (makes it more watery) so that it is easier to drain. Get home and park on a level surface, put the car into gear, and engage the hand brake. If you took a particularly long drive, let the car cool down for a half hour or so, so that you don't burn yourself touching the drain pan or with the hot oil. Pop the hood and take the plastic engine cover off (optional). To take it off just pull it up at each corner. Remove the oil cap and pop out the dip stick:
Jack the car up, or drive up on your ramps. Depending on what jack you have, your jack points could be different, but here is the jack point I chose, and the part where the jack stand goes:
Next remove the bottom cover using your Torx bit. The ST has a little air spoiler on the front that you will need to remove first (3 screws). Once that is removed, take off the remaining screws (8), leaving the one in the very front for last so the cover doesn't fall on you. Then slide the cover forward to release it, since it slides onto features on the underside of the car. Here's the cover and spoiler:
The screws are two different lengths. The 5 longer screws go on the spoiler and on the sides of the cover. The shorter screws go along the front and the back of the cover. I put them on my bench in a little pattern to keep track. In this view, up is towards the front of the car:
Now get under the car and find the filter and drain plug. Both are easily accessible. The filter is towards the front of the car and the plug is towards the rear:
Place the drain pan under the drain plug. Be sure the pan is back far enough to catch the oil since due to pressure it comes out in an arc towards the back of the car. Just position the pan so that one edge is right under the plug, with the rest of the pan real estate towards the rear. Use your 15mm wrench or socket and loosen the drain plug. Unscrew it by hand until oil starts dripping; it is almost out at that point. Keep your hand out of the way and continue unscrewing until it comes out and the oil starts to drain.
While waiting for the oil to drain, preload your filter. Open your new filter, insert the funnel, and pour oil slowly into it to allow the paper filter element to become saturated. Let it sit to soak up the oil, and add more new oil.
Continue doing this until the oil stops lowering, and leave an inch or so to the top so you can handle it without oil spilling everywhere. Also take your finger and add a ring of oil to the gasket:
We preload the filter like this because if we didn't, there would be a time when you first start the car where the engine is not fully lubricated, due to the oil having to first fill and saturate the filter before being able to pass. Some people don't like preloading the filter because it introduces some unfiltered oil into the engine before returning to the filter again. My view is that modern oil is made in a controlled clean environment, comes from a sealed can, and will never be as clean as it is when new. Pick your poison.
At this point the oil should be slowly dripping from the oil pan. Wipe up the area with a paper towel and reinsert the drain plug. The Focus doesn't use a crush washer; it has an integrated gasket in the plug. Torque the plug to 20 ft-lb, or if you have experience with torque tools, estimate. Do NOT over-tighten, since the steel drain plug can strip the aluminum threads in the oil pan if you do. If you don't know what 20 ft-lb feels like, rent a torque wrench from a local auto parts store. Most have a free loaner program.
Now remove the oil filter. I unscrewed mine by hand (there's a good amount of room), but if it doesn't budge for you, use your filter wrench. Let the oil drain and when it's dripping slowly, wipe the smooth surface with a towel to clean it. Make sure the old gasket didn't stick to the metal surface. If it did, remove it.
Screw on your new preloaded filter until you feel the first sign of resistance. Then tighten 3/4 to 1 turn more. Again, do not over-tighten.
Use your funnel and add 5 quarts. Wait a few minutes and check for leaks. If there are none, reinstall the cover (remember to slide it in the mounting features first), then the spoiler, then lower your car to a level position. Add another half quart, wait 5 minutes, then use the dipstick to check the level. The ST supplement manual says the dipstick tube is part of the oil return system and to wait a few minutes before checking the level after adding oil or running the engine. If the oil level is somewhere on the hatched part of the dipstick, start the car and let it run for a minute or two. Make sure you have oil pressure. If you don't, turn the car off immediately. Turn the car off and wait 5 or 10 minutes for the oil to drain back into the pan, and out of the dipstick tube, then check the level again. Add oil until somewhere around the middle position on the dipstick indicator. I ended up using 5.7 quarts to get the level right about in the middle of the range. Check your level again the next day and top off again if necessary.
To reset the Oil Service monitor: with car off, press the push button start with no pedals pressed (get it into ACC mode basically). Then press both the brake and gas pedal together and hold. You'll see messages pop up. Keep holding until you get a message saying the service interval monitor has been reset.
Pour the old oil into the now empty oil containers, and put your oil stained paper towels and old filter in a plastic bag or two. Bring them to any auto parts store or oil change facility and they will dispose of them properly free of charge.
You're good to go for another 5000+ miles!
Addendum:
Some people say you should wait 5000 miles before your first oil change. Here are pics of the new oil and the removed oil (first pic is caps about half full, no flash. Second pic is after I poured both out, so just a thin coating on the white cap, with flash):
Please note that color alone does not indicate bad oil, indeed some brands of oil come out of the can nearly black when new (anyone know what color brand new Motocraft oil is?). However, I also found metal flakes in the oil. It might have been from the oil that I let drain from the filter, in which case the filter did its job, but I'm still glad I got it out of there. Also the old oil did not look homogeneous in color, which is impossible to capture with a camera. It looked "dirty" to me, but I am not a petroleum engineer. Take my observations as you will.
Good luck and have fun!
Discussion Starter #4
Pretty sure the manual specifically says NOT to change the oil early. But thanks for the in depth toturial. Was wondering if the filter would be easy to access or not
Nah, I don't think it does. It just says not to use oils with break in additives. What page did you find that on?
This is a good read. I read it while back when an argument about oil broke out at work.
Top 7 Urban Legends About Motor Oil - Edmunds.com
The only thing i noticed about oil is i have had problems with Quaker state oil. in my old Mitsubishi Mirage I was using Valvoline oil in it at first but my buddy had my jack when i went to change my oil so i took it to a trusted shop and got my oil changed they used Quaker State, with in 6 days my car was leaking oil from the Valve-cover gasket. Car did not leak before anywhere, I thought m valve-cover gasket blew put new one on, and it was still leaking, changed oil... It stopped. I have had many friends had this happen to them using Q-State oil.
Excellent review! I was hoping someone would tackle and document an oil change due to the lower cover. Very informative and much appreciated!
Sorry to burst your bubble, but Quaker State Motor Oil did not cause your problem...............
Whether it did or not, Still won't use the stuff, not going to risk it. Just my opinion. So far out of all the oil i have used I still prefer Valvoline Max Synthetic. I can go to a local shop and get it done for about $35 Usually which it would cost me more to do it my self lol. And lots of times they even throw in a free K&N oil filter, so i won't complain.
I have been responsible for well over 1 million oil changes in my career, I've seen a lot of different oils go in, but most important, I've seen them all come out. Valvoline would definetly be my last choice among major brands, bar none. But hey, it's your car.. Cheers!
I know a lot of people in the Oil field as well I have 6 master Mechanics in my family right now, and none of them would recommend Quaker state at all, most of them will tell you there is hradley any difference between the Major brands of non Pennsylvania Oils, because mots oils still have to follow regulations to be classes as what they are. I prefer using Class 4 oils which Quaker-states does not HAVE at all and The oils i will be using in my car is what ever is at the dealer ship. NO i will not be changing my oil CAuse I can get it done at the Dealer for cheaper. And if something goes wrong i can blame them lol.
ALso you have to put in consideration, When a Automotive companys Runs all there testing on the engines they use only ONE oil only, I know for a fact Toyota in the Camery, Venza and Avalon and most of their A-Series Motors use Castrol GT. So honestly if you want the best performance out of an engine try to figure out what they use in the plant where they built the motor.
I'm also not saying your wrong or anything, I don't know. But i trust my family who's been in the business for a very long time and all of them basically tell me the same thing. When really none of them really talk to each other lol.
ok, where do I begin, first off it's Group IV not "Class 4" and your Valvoline Max Synthetic is neither. Pennsylvania Oils? Both Pennzoil and Quaker State have been out of Pennsylvania for years, they are both owned by Shell Oil out of Houston Texas, and have not to my knowlede been a "Pennsylvania" oil since the 1990's. Tell your relatives things are constantly changing in the motor oil business. If you are looking for a Group IV spec motor oil, better be looking in the European section at you local Walmart or Autozone. Both Pennzoil and Quaker State have a group IV Euro spec motor oil. More importantly, pay greater attention to the ILSAC rating or ACEA rating.................and BTW, K&N OIL FILTERS are a total waste of money, steel and filter media.........
Well its been a feww years but last i read Quaker-State only offered a Group-III mix. At least thats what they carried at my local stores and shops SO my bad. Again Your acting like I'm attacking you, and your all so high and mighty man, so chill out a little. Go around treating every one like that you seem like an ass, sets off a bad vibe. Not saying you are or anything. Just that first impression ya know. I Probably seem like a stupid kid to ya. Which I'm not.
You may be a Expert, but I'm sure if is ask 20 Different experts I'll end up with 20 Different answers. Thats how i feel on the subject.
One thing i know for a fact Having talked to several Automotive Engineers out at Toyota When i worked there is. When they build and engine like i said they use ONE Type of oil on all the testing. If you are able to find out what oil they used that would be most likely your best bet. Simple fact they built the engine around that type of oil. NOt sure if this is true for all Automotive company's but sure it is for most.
Like i said, I'll just be going to the dealership Cause i already asked, for the preferred oil change on the st will only cost me $36 after taxes, Is alot cheaper then going out and buying 6-Quarts of oil not on sale. Plus I don't have all the tools anymore ever since the jack broke and don't have the money for a new one right now.
One last thing I never said i go out of my way for the K&N filters but i am pretty sure they where better then the cheap-o they would of threw on there lol. I normally went with the $5 fram since they just seemed like the easy one to use with the nice grippy stuff on it lol, and have never heard anything bad about frams ever. But you might be able to, lol.
It's all good bro, didn't mean to come off like an arse, just was trying to dispell some possible urban myths.....I will shut up now
Discussion Starter #15
Are you using one jack stand and the jack or is that just a picture before you put the other jack stand under?
That's only one side of the car. That shot is to show my chosen jack point, and where the jackstand goes when you remove the jack. I couldn't jack right by the stand location which is preferable because the jack would be in the way of the stand base. So I had to find another location.
Just changed my oil for the first time, and thanks for the tutorial. One question: In addition to the three screws, the spoiler also has two snaps that attach it to the frame. Can I just pull it away from those snaps, or is there a trick to releasing them? For this change, I left them in place and just pulled the spoiler back to expose the other screws behind it.
I'm keeping some plastic nuts around as well, because I found a couple stripped when I did my fist oil change. $0.80 each at the dealer.
The under engine cover is not hard plastic. It's kind of a semi-rigid fabric. When I removed it, I found salt and small stones up on top of it. Does it really need to go back on? It doesn't look like it offers any protection and any aerodynamic benefit has to be pretty small... I might try it off for a week and see how it goes.
Also, what grade of oil came in the engine from the factory? I just did my first oil change and the oil in there was green tinted and had the viscosity of water...
1 - 20 of 236 Posts
