I'm about to flush out the factory brake fluid and replace it with a hi temp brake fluid, and I understand the clutch uses the same hydraulics as the brakes? So where do I bleed off this line, and is there a certain procedure to follow to ensure the clutch line gets the new fluid as well.
I want to make sure I get the old (lower temp fluid) out of the clutch section of the hydraulic system to make sure it doesn't somehow mix with the new fluid , and therefore lower the rating of the new fluid.
