A couple of things.... You've asked this same question in 3 threads. This will be my second answer. Also this is easily searchable information on this forum or anywhere. That said... No you CANNOT get it. You need Sync 3 which comes on only the newer 16' and up models. Otherwise you need to spend like 2-3k to update your hardware from Sync 2 to Sync 3. There are probably much cheaper aftermarket head units that have android auto, but then you risk losing the steering wheel controls.Says I'm up to date when I check online.
This. It's one of the worst First World problems I have to face in my life. I will seek counseling for this soon. THANKS FORD!A couple of things.... You've asked this same question in 3 threads. This will be my second answer. Also this is easily searchable information on this forum or anywhere. That said... No you CANNOT get it. You need Sync 3 which comes on only the newer 16' and up models. Otherwise you need to spend like 2-3k to update your hardware from Sync 2 to Sync 3. There are probably much cheaper aftermarket head units that have android auto, but then you risk losing the steering wheel controls.
I ran into this on my 2015 f-150. Sync 3 is good, but it's not worth the cost imoThis. It's one of the worst First World problems I have to face in my life. I will seek counseling for this soon. THANKS FORD!![]()
