1 - 3 of 3 Posts
Any owner with the 2867r gen 2. What chargepipe do you have and did it reach the turbo? I have the cobb chargepipe and I had to cut a pipe I wasnt using to extend it(I absolutely hate it). I am going to buy the CPE uncut 90 that they sell. Just wondering what has worked for others. I don't have the stock, the piping was on the car when I purchased it.
Your gonna have to loosen this band clamp up while the downpipe is loose too. I had same issue. Unbolt down pipe from exhaust. The v band clamp for down pipe should be loose too . The intake up top should be unbolted to. The rmm should be on and tight . The turbo should be able to rotate and get everything lined up. Dm me if you need more help . When I say loosen just far enuff to rotate. The pic shows the band clamp to loosen above turbo housing
1 - 3 of 3 Posts
