1 - 5 of 5 Posts
Alright guys, hit a curb real hard the other day on the right side (bottom pic). Wheel is sitting SLiGhT negative camber and steerin wheel is about 10 degrees to the right when going straight. Got under the car to see if I can see obvious damage. Can someone else glance at this and tell me if the control arm looks bent slightly? Also, some of the paint chipping at that section a couple inches from the end is maybe where it bent? Any thoughts?
the control arm doesn't really look bent, I really bent mine hitting a curb. For steering check the tie rod end as that could of bent... I bent it also, the rack replacement was expensive
Despite what anyone says, replace that part, and have the rest of your suspension check AsAp.
Anything bent, or rattles, WILL destroy things.
PLEASE DRIVE SAFELY drifting into a curb is good sign of an error :cool2:
1 - 5 of 5 Posts
