1 - 20 of 27 Posts
I recently started using the COBB OTS stage 1 93 oct map, and the AFR has been around 15.7 at idle and 44.53 at WOT. Is that AFR too high? I've seen usual AFR numbers around 12 idle and 15-16 WOT. Is it dangerous/unsafe to run the car with this high AFR number? I'm going on a trip soon and don't want to run the car if it has potential of hurting it.
2019 Mustang Bullitt
I don't have to much to lend to this, but the 44.53 is decel in gear without throttle input, and should be disregarded. 15.7 seems too lean, someone more in tune with whats up should chime in shortly.
I'm not sure how different car might run on stage 1 93 oct but I'm running stage 1 91 oct and my idle AFR is at about 14 and WOT around 12.
A simple thermodynamic reason why more power is made at rich mixtures is that hydrocarbons release most of their energy on combustion to CO; so for any given displacement/compression ratio/engine speed, etc. complete combustion doesn't lead to highest power output.
Consider the combustion of methane as an example:
CH4 + 2O2 --> CO2 + 2H20
If you took introductory chemistry, recall that standard enthalpies of formation (Hf) allow calculation of the enthalpy (or heat output) of reaction:
Hrxn = Hf,products – Hf,reactants
Tables of Hf can be found in most general Chemistry textbooks. So for methane combustion we have:
Hrxn = [-395 + 2(-242)] – [-75 + 2(0)] = -804 KJ/mol
Now for incomplete combustion the reaction is:
CH4 + 3/2O2 --> CO + 2H2O
Hrxn = [-110 + 2(-242)] – [-75 + 3/2(0)] = -519 KJ/mol
So essentially 2/3 of the energy available from hydrocarbon combustion is generated in the first step (CH4 --> CO), leaving only 1/3 in the second step (CO --> CO2). Conceptually at least, for a given displacement/compression ratio/engine speed the most power would be produced IF we could stop the reaction after the first half of combustion, dump the CO and pull in a fresh charge of CH4. This is hardly practical, but does occur to a certain extent when the A/F ratio is slightly stoichiometrically rich. There are plots of emissions and power vs. A/F ratio in the literature showing that often maximum engine output and maximum CO emission (untreated) coincide.
Clearly in a fired engine both kinetic and thermodynamic effects are operative. But the size of the heat of combustion difference suggests to me that the chemical effect may be the dominant factor.
Founds some nerdy stuff.
One more point to consider regarding running "lean" - if you have more free oxygen available, you are more likely to literally "burn" the iron in the pistons. With a rich or near-stoiciometric mixture, there is little free oxygen to oxidize the iron.
Wow. You need a drink bro.
Blind siding a man with adjacent formulas at this time of night/morning, your eagerness may have gone too far. Lmao!!!
I appreciated this response since I just took 4 semesters of chemistry. Physics and chemistry for the win! Wooooo!
OP you should see around 11.5-12 at WOT and about 14-15 at idle for AFR give or take
Reactions: W4R and Darkdayz23
No throttle decel in the 40s is expected, 15.7 seems a bit lean for idle. You may want to have your tune looked at. It would be worth paying for tune and log review from Stratified or something like that so you can optimize that tune. The car will feel a lot different with that than any of the Cobb OTS tunes.
Or Freektune! Justin just checked one of my logs because I thought I was running rich, but upon further inspection I was hitting target AFR. Put your mind at ease with one of the tuners here
Reactions: Bryman13
Aboslutely. Any of the tuners on here will be a big upgrade from the cobb ots stuff.
Thanks for all the help guys, greatly appreciated. I actually just ordered a flash tune from Stratified, so hopefully it's everything that i'm hoping for. :Rally:
Even an OTS based tune from stratified feels much better than the Cobb OTS. And then you get into the realm of custom tunes and you unlock your cars full potential. I will be going custom tune soon from Freektune and I can't wait
I'm not sure what the etiquette is here: Should I make a new thread for the same issue or is it OK to make a Savior out of old threads and resurrect them?
I installed my short throw arm (JBR, at 20% ... amazing) and forgot to plug my MAF back in (or whatever sensor that is on the airbox). I drove a short bit and had no boost or speaker gauges.
Pulled over, shut the car off, plugged it back in, and just felt like the car was in limp mode.
Flashed the stage 1 Cobb tune and maaaannnn does this thing scoot. I thought I had it flashed before but maybe not.
That said, I'm seeing the same thing as OP. 14.5 or so and these odd jumps to about 43/44 and then back to 14.5. No knock, just an intense torque steer and push back into my seat.
I'm wondering if I should reset to stage 0 and just buy a custom tune from JST (no performance mods yet; was going to buy an FMIC this Wednesday but if I should go custom tune first, I shall).
Should I just get a custom tune? Is the stage 1 Cobb (93 octane) safe to run? Or should I get the FMIC (they're practically the same price)?
2016 Oxford White
14.7 is stoich... I would expect idle AFR to be right around there, and the go fast pedal should make it go down a bit depending how hard you press it. Engines typically like to run a little on the rich side, especially so when really giving it the beans, for engine safety.
40-50 when decelerating is 100% normal. Keep in mind that fuel is being shut off in this scenario so your engine is basically an air pump during this time.
Ahhh ... well that's great news. And actually AFR does drop with throttle. I guess I thought of AFR being in reverse (high is rich, low lean).
Appreciate the info.
Really leaves me wondering what I flashed considering how intensely different these are. Will it "go back to normal" over time? Makes me wonder if I either flashed stage 0 or if I indeed flashed stage 1 before And everything just adjusted lower over time (if that's even a thing).
2017 Kona Blue ST1
Stop advancing stages until you upgrade your intercooler. The OTS tunes are really more for a basic starting point to tune from.
So regardless if you're going to tune or not.
1. Intercooler
2. 1 step colder plugs (gapped to 0.26")
3. (Optional but advised) replacing the factory downpipe with a higher flowing unit.
Look up the reviews for several different tuners here and go with one. Monster, Stratified, JST, Edge, etc...
J
Colder plugs I have and the only stage it's on is the first one that comes with the AP (which, per Cobb's recommendation is for no mods/with a high flowing air filter, which it has ... if there's really any difference between air filters).
Got the answer I'm looking for though. FMIC will be in on Friday. I want to swap the dp but I'm thinking about buying an EFR kid so not sure if it makes sense to buy a downpipe now if I'm going to be changing it out down the road.
2017 Kona Blue ST1
Good on the plugs. Good on the front mount.
The warning about the Cobb OTS is that timing on those tunes can lean towards the aggressive side (as you can confirm) and timing is one of those double edge swords on the EB platform.
Make sure that you're monitoring you ignition corrections & OAR. If you start seeing a lot of excessive negative ignition corrections or that OAR drop from -1 return to stage 0 and check the quality of your fuel.
Stay Safe
J
Reactions: itssocoldinthe
Will do.
Please forgive my ignorance: If I want to change my AP to monitor those ... what would I look for? I do see Ignition Correction (global) and Max and then OA List State, OA Lrn Axis, and and OA Ratio Lrn.
Got one more and then I'll be at work: Is it normal to see AFR jump between 14.41 and 14.99 (usually sitting at 14.7). Not sure if I should keep an eye out for a ground issue (car wasn't part of recall and is a 2014).
1 - 20 of 27 Posts
