21 - 35 of 35 Posts
Discussion Starter #23
TSB- technical service bulletin
it is watt ford uses when something is not a recall, but rather an issue to address on certain vehicles within a model.
Close. A recall is performed whether you car has the problem or not. Example would be the fuel pump recall on the early Focus. If you car fit the VIN range, the recall was performed no questions asked. A TSB is only done if the car exhibits the problem. This is why you need to take the tech out so they can hear the bang or if your car is stalling out, the CEL needs to be there and be able to re-perform the problem. If these were recalls and your VIN/Model were included, you could have the work performed no questions asked.
AAT: Ambient Air Temperature
APP: Accelerator Pedal Position
A/T: Automatic Transmission
AWD: All Wheel Drive
BARO: Barometric Pressure
BPP: Brake Pedal Position
BTDC: Before Top Dead Center
CAC: Charge Air Cooler
CAN: Controller Area Network
CCM: Comprehensive Component Monitor
CF: Cooling Fan
CHT: Cylinder Head Temperature
CKP: Crankshaft Position
CL: Closed Loop
CMP: Camshaft Position
CO: Carbon Monoxide
CO2: Carbon Dioxide
COP: Coil On Plug
CPP: Clutch Pedal Position
CPU: Central Processing Unit
CTO: Clean Tach Output
DC: 1. Direct Current 2. Duty Cycle
DFI: Direct Fuel Injection
DFSO: Deceleration Fuel Shut Off
DLC: Data Link Connector
DTC: Diagnostic Trouble Code
2013 Powertrain Control/Emissions Diagnosis, Gasoline Engines, 12/2012
Introduction 0-7
Acronyms and Definitions
E10: Fuel containing 10% ethanol
E85: Fuel containing 85% ethanol
ECT: Engine Coolant Temperature
EEC: Electronic Engine Control
EEGR: Electric Exhaust Gas Recirculation
EEPROM: Electrically Erasable Programmable Read-Only Memory
EGR: Exhaust Gas Recirculation
EI: Electronic Ignition
EMD: Engine Manufacturers Diagnostics
EMI: Electromagnetic Interference
EONV: Engine Off Natural Vacuum
EOT: Engine Oil Temperature
EPS: Exhaust Phase Shifting
ERFS: Electronic Returnless Fuel System
ESM: EGR System Module
ESOF: Electronic Shift-on-the-Fly
ETB: Electronic Throttle Body
ETBTACM: Electronic Throttle Body Throttle Actuator Control Motor
ETBTPS: Electronic Throttle Body Throttle Position Sensor
ETC: Electronic Throttle Control
EVAP: Evaporative Emission
EVAPCP: Evaporative Emission Canister Purge Valve
FAOS: Fore-Aft Oxygen Sensor
FEPS: Flash EEPROM Programming Signal
FFV: Flexible Fuel Vehicle
FLI: Fuel Level Input
FMEM: Failure Mode Effects Management
FP: Fuel Pump
FPDM: Fuel Pump Driver Module
FPM: Fuel Pump Monitor
0-8 Introduction
FRP: Fuel Rail Pressure
FRPT: Fuel Rail Pressure Temperature
FSS: Fan Speed Sensor
FTP: Fuel Tank Pressure
FWD: Front Wheel Drive
GPM: 1. Grams per Mile 2. Gallons per Minute
GTDI: Gasoline Turbocharged Direct Injection
H: Hydrogen
HC: 1. Hydrocarbon 2. High Compression
HDR: High Data Rate
HO2S: Heated Oxygen Sensor
IAC: Idle Air Control
IAT: Intake Air Temperature
IFS: Inertia Fuel Shutoff
I/M: Inspection/Maintenance
IMRC: Intake Manifold Runner Control
IMTV: Intake Manifold Tuning Valve
IPC: Independent Plausibility Checker
IPS: Intake Phase Shifting
ISO: International Standards Organization
KAM: Keep Alive Memory
KOEO: Key On Engine Off
KOER: Key On Engine Running
KS: Knock Sensor
LDR: Low Data Rate
LONGFT: Long-Term Fuel Trim
MAF: Mass Airflow
MAP: Manifold Absolute Pressure
MAP/IAT2: Manifold Absolute Pressure/Intake Air Temperature 2
MFF: Misfire Freeze Frame
Introduction 0-9
MIL: Malfunction Indicator Lamp
MRFS: Mechanical Returnless Fuel System
MSOF: Manual Shift-on-the-Fly
M/T: Manual Transmission
NOX: Nitrogen Oxides
NVLD: Natural Vacuum Leak Detection
NVM: Non-Volatile Memory
NVRAM: Non-Volatile Random Access Memory
OASIS: On-line Automotive Service Information System
OBD: On Board Diagnostic
OL: Open Loop
ORVR: On Board Refueling Vapor Recovery
OSC: Output State Control
OSR: On Board System Readiness
OSS: Output Shaft Speed
PATS: Passive Anti-Theft System
PCM: Powertrain Control Module
PCV: Positive Crankcase Ventilation
Pd: Palladium
PID: Parameter Identification
PIP: Profile Ignition Pickup
PPM: Parts per Million
PSP: Power Steering Pressure
Pt: Platinum
PTS: Professional Technician Society
PWM: Pulse Width Modulation
PZEV: Partial Zero Emission Vehicle
RAM: Random Access Memory
Rh: Rhodium
ROM: Read-Only Memory
0-10 Introduction
RPM: Revolutions Per Minute
RWD: Rear Wheel Drive
SAE: Society of Automotive Engineers
SCB: Supercharger Bypass
SFI: Sequential Multiport Fuel Injection
SHRTFT: Short-Term Fuel Trim
TAC: Throttle Actuator Control
TACM: Throttle Actuator Control Motor
TC: Turbocharger
TCBP/CACT: Turbocharger Boost Pressure/Charge Air Cooler Temperature
TCBY: Turbocharger Bypass
TCIPT: Turbocharger Intake Pressure And Temperature
TCM: Transmission Control Module
TCS: Transmission Control Switch
TDC: Top Dead Center
TIVCT: Twin Independent Variable Camshaft Timing
TP: Throttle Position
TPPC: Throttle Plate Position Controller
TR: Transmission Range
TSB: Technical Service Bulletin
TWC: Three-Way Catalytic Converter
VCT: Variable Camshaft Timing
VECI: Vehicle Emission Control Information
VID: Vehicle Identification
VIN: Vehicle Identification Number
VR: Variable Reluctance
VSS: Vehicle Speed Sensor
WOT: Wide Open Throttle
CF: Cooling Fan
CL: Closed Loop
CO: Carbon Monoxide
CO2: Carbon Dioxide
COP: Coil On Plug
Introduction 0-7
FP: Fuel Pump
0-8 Introduction
H: Hydrogen
HDR: High Data Rate
KS: Knock Sensor
LDR: Low Data Rate
MAF: Mass Airflow
Introduction 0-9
OL: Open Loop
Pd: Palladium
Pt: Platinum
Rh: Rhodium
0-10 Introduction
TC: Turbocharger
ok....you win!!
Another one I can't seem to find a definition for. What are these stages everyone keeps labeling their mods too..
Stage 1
Stage 2
Stage 3
1. Is intake with a tune.
2. Is intake and larger intercooler with tune
3. Is everything above and a downpipe.
4. Is everything above and a big turbo.
BBC
Big Brake Change
For example: I did the BBC on the front. Waiting for the rears to be shipped.
BSD? As in DHM BSD?
21 - 35 of 35 Posts
