1 - 10 of 10 Posts
Please I’d love some proper advice other words pro advice on how to down shift rev match properly like a simple step by step of what others prefer to do
Discussion Starter #2
What I’ve been doing is engage clutch in 4th gear /switch into 3rd rev match 3 -4K depress clutch and add throttle although sometimes I wonder if I’m doing small power shifts becase of to much throttle after clutch release ?? :)
2014 Ford Focus ST3
I was trying to teach my wife but I’m not the best teacher.
I found this guide to be the best imo
Rev Match Downshift
Reactions: wingnutt
Bar none best video out there is Matt Farrah's on basics of driving a manual. Best part is, he uses his Focus RS in many of his videos - same transmission as the ST.
Look up team o'neil on youtube, they are a rally school. They have a few videos going over heal/toe, downshifting, revmatching. Some good information and in car videos. After you get a better understanding of the process, you just need practice. You can do that while driving spirited or even just on your daily commute, just keep working at it
Discussion Starter #6
Thank you all very much I have the downshift revmatch down pat at lower speeds now but I still struggle around 50mph 4th to 3 for some reason I get it perfect some times then others a lil over rev ?
Anyone else use a pedal spacer? I find the stock placement of gas pedal to be way too low.
2014 Ford Focus ST3
Op, if you watch xTheMan42 linked video, you'll notice all his blips aren't always perfect either. Just keep practicing until it becomes 2nd nature.
yes, i have a 3/8" spacer that i find helped keep my foot where i needed it. Lots of different sizes/options, just need to figure out if you want a little spacer or larger. Will be personal preference; goldie lox ;)
I do same thing as when upshifting, push in clutch as I let off gas, then delay letting out clutch a bit when in new gear so revs go up higher as I give it gas so that revs match. Also, I don't downshift when stopping, only when slowing down. For stops, I just put it in neutral and brake to a stop. That's just personal preference, lot of people downshift through all the gears when stopping.
1 - 10 of 10 Posts
