Hello guys, since day one my ST has been having problems with temps, both coolant and oil. Whenever I turn on my A/C the coolant temp will never past the 1/4 needle gauge, if the ac is off it will get to the ideal temperature (half way). If I'm at ideal temperature and turn on the AC the temp will fall again to the first mark. Oil temp is always at 1st mark unless I punish the car ( trackdays or something). The dealer already checked the thermostat and it is working correctly, an update corrected the idle stalling problem. Do any of you have any idea about what could it be ?
