1 - 3 of 3 Posts
When I put in the 20mm spacer for the front, the spacer moves about a half a cm when i try to spin it. Is this normal? Or does it have to be almost glued in when i put it in? (This is all before i put the supplied nuts in)
Sounds normal to me. Just a little side to side movement if it’s pushed all the way to the hub?
Yes, like when you try to spin it counter/clockwise, just moves a tiny bit. But ofc if supplied nuts are put on, the spacer fits well with no movement
1 - 3 of 3 Posts
