1 - 8 of 8 Posts
Hey all, I'm having an odd issue. Sometimes at WOT I get what feels like small misfires. I have half second losses of throttle a few to several times in a row. It's not every time I hit the throttle. Has anyone else had these issues?
Ps I did check for codes. I have no CEL. I do how ever have these two codes
P26DE
U0284
Someone else....lolms3 i think it was, had similar issues that turned out to be a boost leak.
Sent from my SM-N910P using Tapatalk
I wasn't getting codes but I 100 % can say that I was having the same problem as you were but no codes. I went a step colder with new plugs and it has yet to happen again!
Discussion Starter #5
I suspected sparks.. But alas, when I attempted to open my hood, the cable wouldn't pop it! I'm seriously getting sick of this. I can't even pop my hood.
What are the signs of a boost leak @sullyman86 @LOLMS3
Those codes are for the sound symposer and grill shutters.
Spark gap more than likely.
Boost leak will probably have high pitch whistle turbo sounds, and PERHAPS a stutter or two when accelerating. Really Depends on the boost leak. I had a charge pipe that was coming loose, and still hitting peak boost, and logs looked clear, till it blew off completely.
1 - 8 of 8 Posts
