So I changed my battery this past weekend, after 3 years in Phoenix, and I had a bit of a problem. The positive terminal was corroded to the point it corroded the little white wire enough to cut it away from the terminal. I am not sure what this wire did because I connected the Positive terminal back up and the car has been running fine the past two days without a problem. Does anyone know what this white cable connects to?
