1 - 7 of 7 Posts
Hey ST peeps. I need some help please. I'm only getting 15lbs of boost on my 2015 ST. I'm running a Cobb accessport roush intake borla cat back cpe intercooler and mbrp charge pipes. I have the access port flashed to stage 2 and in mode 1. Any help would be appreciated!!
Check for boost leaks around the charge pipes or the BPV may be sticking or leaking. I had an issue with my Mountune sticking at limiting boost.
I think he meant BOV, which is the blow off valve...
Not to stupid but what is the BPV? I'm an old head new to this turbo stuff?
Yeah the BPV (by-pass Valve) is the OE operation where it by-passes back into the intake, where a BOV (blow off Valve) usually vents to atmosphere. The Mountune BPV operates like OE just with a superior design, and most of the other types all vent to atmosphere or 50/50.
1 - 7 of 7 Posts
