I was leaking oil from the pressure switch...not much at all but noticeable on startup, parking, parked, etc. Maybe .5 a qt between oil changes. I made sure the switch was tight, started it up and it got worse. I then put a new switch in I got from ford which was vin matched but looked different from the one which was already in my car. I put it in and tightened it down, and it started DUMPING oil on the ground...I need help because my car is undriveable at this point and its my daily...borrowing a friends S10 for the time being till I can figure out how to fix it. I went to losen the new switch and it snapped off. So I have to replace the whole housing now, ordered the parts already to fix that because I can't remove the aluminum bolt part of the switch...
EDIT: I can't find any information on the torque for the switch either. Any and all information is helpful.
HELP PLEASE
