Hey so I recently replaced the engine on my 2013 st using a 2015 escape engine. The problem now is the car is having trouble starting up . Having trouble posting a video of it on here
If a leak-down test doesn’t show a leaky gasket or valves, 98% chance it's a failed ringland on the piston.Quick question you think I could get away with just fixing the no compression on cylinder 1 on old motor? All the the other cylinders are showing 150 across
