Ok, so I got my Cobb DP installed today but I got a problem. When midly accelerating the downpipe is touching a beam for a second causing a rattle. I've attached the pics (not my pics but pulled them off the Net for visual aid). The shop that did the install of the DP told me I had several options but didn't want to do it themselves because of the liability. One of the options they told me was to take a crow bar between the beam and DP and see if I can create a little more distance between the two. Another option was to heat up the beam a bit and then throw a chain around it and pull down or hang from it to increase the gap between the beam and DP.
Anyone else run into this situation already and have other ideas??
