1 - 6 of 6 Posts
I just finished installing my ATP GT3071r, first start up seemed fine. it had a little rising smoke from the turbo just breaking in. After it settled everything was fine. Then it sprung an oil leak from the oil feed like from ATP. Common issue ?
it’s coming from the 90 degree fitting. it seems to be the line and not how secure it is. it’s tightened quite well
undo it and check it out...gotta be an easy fix ?
Okay so i undid it, turned out one for her threads backed out. i temporarily fixed it to see how’d it hold up u til i can afford to get another line. I took a bit of gorilla glue and used that as a sealant around the threads. It worked beautifully, if i ever needed to bread it off i’ll just use a torque wrench and go to town. for now it’s holding a lot of oil pressure so i think i’ll just be fine, or have the slowest leak ever which i’m okay with being that i change my oil every 3,000 anyway
Glad you got it fixed.
2013 Oxford White Focus ST3
1 - 6 of 6 Posts
